FishingAddiction
- Sep 5, 2009
- 26
I just bought a little 12' Jon Boat with a 1984 15 hp Evinrude and a 6 gal tank. I took it out on a lake near by and it ran fine with no problems at all. So I did a few modifications and added a deck up front and moved the 6 gallon tank up front so I could ride by myself and have a little weight in the front. Boat had a little trouble starting the next time I took it out but finally go it started and it ran fine. But at random times when I'd go to start it it would start up and die and then Id have to yank on it several times before it would finally get running well again. Then when we were getting ready to leave it took half an hour to finally get started and then as we were running it died. I figured out I had to pump the ball after a min or so to keep the motor running. So all the way back in as we were running I kept having to pump the ball when the motor would start slowing down and sounding like it was going to die. I thought it might be the fact that I moved the tank up front but I moved the tank back to the back with a shorter hose as a test and it is doing the same thing. I can get it running right away now but to keep it running every min or so I have to pump the ball. I redid all my fittings to make sure I wasnt getting any air. Cant figure out what it could be.....any ideas? Sorry for the novel. Any input is much appreciated.
