Re: i cant get the pistons back in the bores
i got the same thing too....
http://www.jegs.com/i/Sealed-Power/844/E251X/10002/-1
I was going to say match them with the old or go down to the auto parts store and match them up to a new set..might have gotten the wrong ones in the box...
and yes the oil top and bottom rings are suposed to sit on the little lip of the expander ring...
once the assembly is togetther is should spin on the pistong freely and the top and bottom scraper rings should slide freely around the expander ring...
when i put them together like I said i hold the expander mating ends with my Left thumb...I hold them so they stay mated and not over lap...
those would put them at the 9o'clock position then I start with the bottom scraper ring..I start that onceat the 6o'clock position and wind it around the expander...once done it should slide easily anywhere...
but I leave them in that position....then I start the top scraper ring and I start that at 12o'clock...and wind that on....
after that they should be free and the installer tool should compress the rings easily...
I would try it with just the oil ring installed...once you get it in the bore to make sure it fits then add the other rings and seat them too....
here is a little something that may help....
http://books.google.com/books?id=p1...e&q=how to install oil expander rings&f=false
