99z286spd
- Sep 1, 2009
- 29
Im new here and i have been doing a LOT of reading and searching and finally sighned up. I aquired a wellcraft 17.7 bowrider boat through Craigslist 4 months ago for free! I was told it wouldnt run. I'm always up for projects so I went for it. It had a 90 hp e-rude 1982. I got it to run but not well. It wouldnt idle well but WOT was ok. After tinkering for awhile I bought the manual and found I had 10 psi comp in one cylinder causing the poor running. I researched rebuilding prices and was very depressed as i did not have 3,000 to do the job right(I wanted complete not just powerhead). So I took a chance and searched for a few weeks and found a used engine complete on Ebay E88MSLESA for 650.00. The guy was real cool about it and took 150.00 dollars off the price because of a leaking lower end plug. The engine had sat for a few years and was told it ran well when last run. I got the old engine off the boat and mounted the new one. I got it fired up after cleaning carbs, fuel pump, and new H20 pump. The engine ran good and smooth but after it got up to temp it started spitting. I took the cover off and noticed spark jumping on two of the coil packs. Apparently there was cracks in them. So since my old engine had brand new every thing, i swapped the coil packs, wires and plugs. I did not refire the engine..I just assumed it was all good. Well..got my boat to the ramp, 10 miles away, and backed her in. I tried to start the engine in the water but it would only start and die instantly. I advanced the throttle all the way and got it running but would only run higher than 2k rpm otherwise die. I killed the battery tryin to fool with it, took it home and put a tank under it and a battery charger. I got it running by advancing the throttle again and fooled with the plug wires. 3 wires off had no effect how the engine ran. But one wire made it die instantly. I used pliers to touch the coil wire from the power pack to the coil and voilla!! I heard that cylinder pick up. The other side with both wires off... i touched the plug wire that went to the bottom cylinder to the top cylinder plug and that cylinder picked up!! Then put the last one on the bottom cylinder and that one picked up!! Then i went back to the lake and it ran awesome!!! I am very happy with the deal I got. I guess the moral of the story was is that i didnt pay attention to the wire colors and the wire that goes to the coil from the power pack, the metal spring clip came out on one of em cuz i didnt take care when i removed it from the old coil. I'm sorry bout the long rant but i guess i needed it. I kinda wanted to "introduce" myself too so people know my story. I never had a boat but I am hooked now!!
Thanks
Leon
Thanks
Leon
