83Evinrude
- Sep 3, 2008
- 290
Will be performing transom service on my 2004 VP SX outdrive after the season ends. Would like to change the Gimbal bearing, Both belows and probably U-Joints. Should anything else be replaced while I'm in there?
I have questions about parts and tools. On the Gimbal Bearing and Belows, are aftermarket (Sierra, Mallory etc.) ok or should I go for Genuine VP parts? Doesn't look like VP sells the U-joints only a complete shaft assembly. I do have a VP SX Outdrive Manual (Thanks, Don S).
iBoats sells a complete transom seal kit here
iBoats sells U-Joints here but I'm not sure which I need, any ideas?
_________________________________________
I know I will need an Alignment Tool and probably a Gimble Bearing Installation Tool. Is there a Gimbal Bearing Seal and if so is a Tool Required for this? Any tools required to remove and replace the Belows?
Is this Alignment Tool ok?
The same seller sells this to install the Gimbal Bearing
He also sells tool sets, this one has the Alignment Tool, Gimbal Bearing Installation Tool and Gimbal Bearing Grease Seal Installation Tool. Does my outdrive have a Gimbal Bearing Grease Seal?
This set has all of that plus a tool for the belows.
Which tools should I have for my outdrive?
My outdrive does not have a trim tab fin. It does appear to have a hole to mount one, but no scratches in the paint where one has been. iBoats sells a Sierra replacement one here.
Did Volvo not put fins on some outdrives? I have not noticed any problems with steering torque, should I order one?
Any advice on parts or installation (tips, techniques etc.) will be greatly appreciated. Thanks.
