BAproject
- Sep 2, 2009
- 276
Re: 1991 Bayliner Capri Bowrider
Hey guys,
The bolts for the starter come off the backside of the engine. I could get a wrench in there with an extension and most likely yank the starter with a little patience.
The bigger problem is that motor has been sitting for 5 years and needs a major overhaul. This cannot be done from inside the boat. The previous owner did not winterize it and it was used more often in salt water than anything else(I am in the northeast).
Pulled off the water pump and there's rust....not a good sign!
I am in the process of getting the crank pully assembly (which was taken off the motor before I purchased it) so I can see if it will even turn. I am not hopeful, but it gives me a good excuse to pull the motor, pop the heads (which can be done b4 pulling), and see what kind of shape the cylinders and rings are in. Even if it spins I would hazzard a guess that compression in the cylinders will not be optimized if even present.
Even better with the amount of corrosion at most of the hose connections it would be wise to flush the entire block to make sure that the cooling channels are not clogged or even too badly corroded to salvage (this of course would be bad!)
Will have to check for a cracked block as well, but the good news is the oil in the pan is good, clean, no water, smells like clean oil and is not even close to being broken down.
Any advise at this point from someone who has come across a similar situation would be welcomed. I might be better off getting a crate engine and dropping it in?
-BAproject
Hey guys,
-BAproject
