TrustyJohnson
- Aug 25, 2009
- 7
Some friends and I recently purchased a 16' Starcraft and along with it came what we believe to be a 1962 Johnson. We can't find any identification plate on it and based on the writing in permanent marker on the inside of the top cover, it wouldn't help anyway. The writing says "1962 Top End 40 HP Lower 33 HP Johnson".
We ordered a new impellor for a 1962 40 HP motor. It turns out that the new impellor is quite a bit taller than the original we took out and wouldn't fit in the housing. Can anyone verify that there is a difference between the 33 HP and 40 HP impellors? Also, are there any tell tale signs that we have a 33 HP lower as opposed to the 40 HP? Remember that there is no ID plate or any date markings other than the permanent marker inside the top cover. Thank you in advance!
