cutlass185
- Aug 31, 2009
- 17
I'm having an issue with my boat, last week when starting the boat the starter seemed to be sticking open after the boat started. After going for a 20 minute ride in some pretty large waves we shut the boat off. Upon restart the starter wouldnt engage the flywheel so the issue was investigated, the long starter bolt had broken so the day on the water was done..... the next day i drilled the broken bolt out and got new ones, went to run it in the driveway and the starter engaged into the flywheel for a fraction of a second, I turned the key off right away and the current wouldnt quit, the stud on the battery actually mented off while i was trying to loosen the wing nut. I took the starter off and had it tested, wasnt working so i replaced the solenoid, tried it again, same issue. I replaced the engine mounted solenoid this morning and went to install the battery cable and it sparked right away so Im not sure whats going on, I thought maybe the ignition switch was bad but i pulled the fuse and it still sparked as soon as i touched the battery...... anyone have a suggestion i could try? thanks!
