Re: saftey alert questins on stainless steel fuelfill
Some boats have a grounding plate located either on their transom below the water line, or the bottom of the hull, which grounds the stray currents to the natural ground".
If your boat doesn't have this feature, then grounding to the engine block does the same thing thru the drive unit.
It's also possible to ground to a metal thru hull fitting, if the boat is not kept in a slip, or mooring. I think that the possible galvanic destruction of the fitting would make it too dangerous to use this method on a "wet" boat.
