nthrnNYker
- Aug 28, 2009
- 22
I just bought a '83 Bowrider Capri in pretty nice shape, along with an 85 hp Chrysler Force engine...a hellova deal on both.
When I got the boat, it had a full tank of gas, but it just didn't have the strong smell of gas, so I replaced the gas in the tank, then drained the bowls on all three carbs....water in the bowls in all three. I replace the bulb and the quick-release tank connector...as both were leaking pretty good and sucking air.
I got it to idle after a bit at home, and it would rev up pretty good as well...so I took it out on the lake for a test run.
Once out on the lake, the motor would stall at idle unless I periodically hit the electric choke on the ignition switch. The friend I was with, who had a bit more experience than I with outboard motors, temporarily bypassed the neutral safety switch so that the motor would start in gear. Once he did that, it would still stall after a very short period of time, but he tried to immediately open up the throttle while in gear. OMG, did that engine take off. That thing just FLEW with nary a hiccup. We went up the lake about six miles and back and that engine PURRED the whole way !
However, as we neared the boat launch, we dropped the speed of the engine. At just under 1/2 of WOT, the motor started to seriously sputter and cough, and as we decreased the rpm of the engine even more, the engine died. It would start up again, but unless we choked it periodically with the ignition switch, it would immediately die.
Now, my friend says it sounded like the low-speed jet was obstructed, and just needed cleaning and/or blown out with compressed air.... but I would hate to take the whole contraption apart just to clean it, put it all back together and not fix the idle issue.
Would it be better to rebuild the carbs while I have them apart ?
(please keep in mind I am not a mechanic and tend to have leftover parts when I am done )
