I have a 1988 Lund 5.5 Tyee. I love it! it is powered by a 1987 Suzuki dt 85.
Here is my problem.
It seems that as the fuel tank empties, the ball won't pump up. I have rebuilt the carbs, changed the fuel filter, rebuilt the fuel pump, tightened all the fittings, replaced the suziki connecters, checked the lines for pinholes. NOTHING helps me as the tank empties to keep the bulb hard. This thing runs great at faster speeds, but trying to idle at the dock or slow troll simply empties the bulb, which won't then pump up.
I have removed the fuel line from the motor via the quick connect and attempted to pump up the ball that way. It only pumps up hard when the tank is full. When it is down to 3/4 the ball won't pump up.
Question?
Has anyone ever even heard of this? Could it be an internal tank problem with a pinhole or something in the pick-up pipe within the tank? Also, at times my fuel gage sticks on full, even after it has read 1/2 full.
Are these 2 seperate problems?
i am going to try an external tank to see if the engine will idle and troll, and will keep you updated.....
Help anyone???
Here is my problem.
Question?
Help anyone???
