Briand3096
- Aug 21, 2009
- 18
Ok I have a 1986 Johnson 40HP. Bought the boat in NONE running shape. When checking it out I noticed no fuel. Started with new fuel pump. Then it ran only with choke on. I removed the carbs cleaned them and rebuilt them. I soaked them and took everthing out when soaking. I also noticed on the lower cylinder the plug wire was bad. I bought a new wire set and plugs. The motor runs allot better now but still not ideling. I retested the wires again and the same wire is bad and this is the new one. Can something cause a wire to fail? This dam motor is doing my head in now. Any help please.
Thanks, Brian
Thanks, Brian
