On my Maxum, there's an unused switch labeled ACY that is already wired to a 5A fuse in the fuse box. I just connected them to the output of that switch.
If you aren't in a hurry to buy, look for LED rope lights around Christmas time and see if they can be cut and run on 12 volt.
I had been looking for lights for quite a while. Thanks for the thread. I got the red ones. I was afraid that the other colors would effect my night vision. Red lights were all we used on the bridge of the ships I was on. I will get some pictures after I get them installed.
I think they added that the model year after mine. I guess the Anchor/Nav switch is the only option for me. That is a nice mod.
I used a set of the HF fiberglass wire snake kits to hold the wires and rope lights up under the gunwales of my boat....
I tried some green ones from Ozium. Little bugs that look like miniature mayflies attacked them. They also screwed up my night vision but they weren't angled down enough. I'm gonna try red. I bought both. The thing about LEDs is the narrow spectrum of light they put out can be kinda creepy.
Yeah, the 120VAC one I got was normally $10, bet the LED ones are $20-30...
NOw they are about $5 - $10 - I thought of trying this as I read an article about LEDs being of low-voltage and that 120V applications were stepped down in voltage and were also DC since they were diodes.
Well. I can tell you that the strand of 4.8 watt LED christmas lights I got from my local ACE Hardware do not work on 12V.
Any thoughts?
