Re: 1974 Phantom Boat W/ 1961 Johnson Super Seahorse 35 Motor
Joe, welcome to the iboats.com forum. The experts here, which I am not, can help you with any problem. They may be waiting for you to spell out the problems you need help with. Meanwhile, I can help you with the motor a little bit. If it really is a 35HP Johnson, then it is not a 1961 model. Last year for 35's was 1959. If it really is a 1961 Johnson Super Seahorse, then it should be a 40HP motor. The only way to know for sure is to find a quarter-sized aluminum disk on the powerhead and tell us what is on it. Should be something like RD or RDS 21, 22 or 23. After we find out what motor you have, I might be able to help you with a service manual. Good luck!
EDIT: The link below is to the USCG's Manufacturers Identification Code (MIC) database which lists three different builders of Phantom Boats, only one in Texas. Some names, addresses and telephone numbers included which may be a source of information about your boat. I was able to find good contacts in the MIC on my 1996 boat eventhough the builder was OOB.
