I took both carbs off of my motor to rebuild them, and the dismantling instructions say to remove the cover plugs and intermediate orifices. All four ports, (2 on each carb), appear to be sealed from the outside (looks like lead caps), and are not removable. Is this a factory thing, or has someone snapped them all off? Do I really need to get them out or can I soak the carbs as is? If I have to pull them, should I drill out the cover holes, try to melt the plugs with a little heat, or what? If I pull the "freeze plugs" from the inside and replace them will I be OK? I'm lost
