BackWoodsTracker
- Jul 31, 2009
- 52
Yes I did read this
Cutout switch
The cutout switch should also be checked. The correct adjustment for the switch is to activate when the switch arm has moved 1/8". Check this with a 1/8" drill and a multimeter. With the key 'OFF' put the multimeter across the switch (points ignitions will have to have the points open for this) and start moving the switch arm. When the meter shows that the switch has closed, check the gap between the switch arm and the actuating lever, it should be 1/8". Bend the arm of the switch to achieve the dimension.
__________________
My boat had points, but has been converted over. When I put the meter to the two wires, and the meter set to where it gives a sound, no matter what I do with the switch, it still buzzes. Am I using the wrong setting or what? If I start the motor and activate the switch, it kills the motor, so I know the switch is good. Also, am I putting the drill in the right place, just under the roller in the little valley, or should I be in a different spot? I have the feeling I'm not the first one messing with this, the arm was bent to where the switch didn't activate til it was at the top of the peaks. I have new cables in it now, and they are adjusted properly. Lake test is tomorrow again and I would like it to go smoothly for my dad. He's been patient with it so far, but he needs it right soon, or he might toss me overboard!
Cutout switch
__________________
