jmarine225
- Jul 13, 2009
- 95
Hello all. I was just doing some routine maintenance going through my cooling system and found something unusual. First off I have a 93 OMC Cobra 5.8L. I removed one of the water lines that feeds into my manifold to check for any blockages in the hose or the manifold when I found a solid chunk of mud in the hose. Curious how that could happen. I then proceeded to clean out the manifold from the inlet with a wire brush, as good as possible to be sure of no blockages. Everything seemed clear but there was definitely some mud in the manifolds also. Tomorrow I will work on the riser before moving to the other side. I burned up an exhaust hose in the past and even though it's not showing an overheat on my gauge I guess I'm paranoid something may still be causing an overheat. What could be the cause of the mud in the there and will the cleaning of the manifolds and risers with a stiff wire brush be effective to clear any blockages? I plan on changing the manifolds in the off season as they appear to have had their time.
