I just recently purchased a boat with 1973 OMC 140hp sterndrive and do not know about I/O. Doing some routine maintanance of changing plugs, oil and filters. I have a few questions. I would greatly appreciate if someone could please answer.
1) How do you change the oil in the intermediate housing. I see the fill screw on the top port side, but do not see any drain plug.
2) To change the ball gear a major job?
3) Are props still available for it? It is a one inch smooth shaft?
4) Are there any do's or don'ts?
5) Anything I should change or be on the look out for?
6) What is the best way to flush the motor? The book said there is a flush kit adapter. Do you know if it is still avalible. I've been putting a container under it, which is a pain.
Thanks
Thanks
