Re: Trim/Tilt Gauge only works when the key is off
Yes, it works perfectly when the key is off, but pegs full down as soon as I turn the key on. I guess the previous owner must have been messing with the wiring.
Check the back of the gauge and make sure it's wired correctly. Should have three (or four) wiring connections labeled
I - Generally a purple wire leading to an ignition wire somewhere. This is often (usually and acceptably) simply daisychained to the "I" (purple wire) terminal of another gauge, but eventually daisychaining on back to the "I" terminal of the tachometer. It is wired this way (purple/ignition) instead of directly to power (red/constant 12V) so that the gauge only comes on when the key is on.
S - this is the sender wire from the T/T sender back at the engine.
G - a (usually) black ground wire directly wired to a grounding terminal under there somewhere. Sometimes people daisychain these to other G terminals on other gauges, but it really should be grounded itself.
The 4th terminal is near the light bulb and is wired to the switch that controls lights - or again, sometimes daisychained to the same terminal at another gauge.
