So i am thinking about what kind of wood to use for my stringers....
The fiberglass around them is in really good shape so I would like to just cut the top off, scrape out the wood and put new back in, then fiberglass over the top...sound like a plan???
The center stringer measures 1 1/4 inches wide so shoud I get two sheets of 5/8 plywood and slide it in? That sounds like the most logical approach at the moment. I could probably use the trimmings off the deck because I plan on using 5/8 for the floor.
The two outside stringers are also 1 1/4 inches wide, however the 4 short ones running the width of the boat are 1 3/4 inches wide. I guess i could use one sheet of 1 inch and one sheet of 3/4.
Waiting on the snow and rain to stop so I can go get some plywood!
