soaringhiggy
- Jul 1, 2009
- 167
Re: why does everything happen to me?
stupid question, you did open the vent on the tank?
i have a pressure tank which is yes in great working condition
pressure tank acts as a fuel pump using pressure from the crankcase to supply air pressure to push the fuel to the carb.
There also has to be another vent on the tank, as when the gas expends when boat is not in use, it will push gas out the carb and pressureize the crankcase.
no so, the pressure fills the carbs, float needle stops flow. the tank and hose is a sealed system.
