I have a merc 4.3l v6. Unfortunately it got washed ashore and filled with sea water last year. We lifted it out straight away and got everything running as normal before fogging the engine and spraying a couple of cans of wd40 everywhere. I went to use it this year and the starter was clicking, I took it off and it was rusted inside so I have bought a new one. I am concerned that the flywheel could be seized as well, is this possible. The small section I can see looks a bit rusty but solid and I can't turn the crankshaft. There is no water in the oil and the camshaft turns easily by hand but not the crankshaft. Should I just give the new starter a go and see what happens?
Also, the starter solonoid has two small studs and I only have one small cable, does it matter which one I connect the small wire to?
Thanks in advance
Thanks in advance
