hello,im changing the bottom portrion of the leg (on a 35 hp johnson 1979 sea horse)the used part I have is from a short shaft the runnig motor I have is a long shaft.The impeller shaft was easy but the shifting rod goes down in behind the prop so,I have the prop off and I see 2 small bolts deep behind thethe bracket that the prop rides against.how do I get in there to realese the shifting rod?anyone know? any help would be great thanks
