Re: My Mariner 60 is tempermental
Here is an update of where I am at. I finally did some testing...
I have been suspecting ignition problems all along. Last night I hooked up the garden hose & earmuffs, took the cover off, and started the motor. I then pulled plug wire #1 off the spark plug (with thick rubber gloves and my fingers crossed for luck). The motor died. I did the same with #2. The motor died again. I did the same with #3 and the motor kept running like it had no clue I just pulled a plug wire off. Ahhhh yes, ignition problem on cylinder #3!
I then temporarily switch plug wires #2 and #3 and repeated the test to see if the problem would move to cylinder #2, pointing to a bad plug wire. Nope, plug wires are fine.
I then re-wired ignition coils #2 and #3, swapping the plug wires and trigger wires to see if the problem would move to cylinder #2, pointing to a bad coil. Nope, coils are fine.
Which brings me full circle back to the switch box. I ordered one from O'Rielly Auto. They were a lot more $$$ than this site, but I will have it tomorrow morning.
Results to follow.
Pool Guy
