Hi,
I am having a problem with a 2002 F115 (~ 400 hours) that is on an 1801 Century. I am not getting full RPM?s. It will only reach about 5,000-5,200 and does not seem to have full power. I have changed the prop from a 19K to a 17K, both which are the salt water series (did not make a difference). I have also checked and cleaned the VST tank, changed the fuel water separator filter, changed the impeller & thermostat, spark plugs, check fuel pressure (39 lbs) and did a leak down test (4%).
The only thing I did notice was that the plugs are a little black (running rich?). Any information or suggestions you could make as to what is going wrong would be greatly appreciated.
Thanks,
Bob
Thanks,
Bob
