Re: 1977 evinrude 140 hp thermostat removal
It should be the same as my 85 hp. Below the lower cowling is another cowling, bridging the gap to the lower leg. It's held on by 4 bolts on the transom side of the leg, plus 2 more inside the lower cowling going down, under the bottom of the heads. With this cowling removed, you can use an offset box end wrench to get at the 2 thermo housing bolts. Be very careful removing the bolts though, as in snapping a head off, or the bolt head actually disintegrating, you will be required to drop the lower cowling to drill out the bolt.. I haven't done my stat just for this reason yet..
