Re: 5.7L Mercruiser HP Question
Most likely its the 260HP 5.7. Might be a 220HP.
I would assume that your running an ALPHA 1 outdrive. On the top half of the ourdrive you have a gearing lable. it would say something like 1.50 (as an example). Thats your outdrive gearing.
What are your RPM's at WOT? Your running a 19* (pitch) prop, which is a good all around prop.Understand that if you go larger your boat might not be able to turn the prop as fast (engine rpms lower) and you could not only losr top speed, but your "Hole Power" to plane will also be a little weaker.
I run a Stiletto 19* 3 blade on my 22' Ski boat. I have 1.50 outdrive gearing, and Im doing speeds of 55-58MPH at 5300RPM's with me and 1 other passenger trimmed out at Lake Powell ( 2000' elevation) Up here at Utah Lake ( 4500' elev.) I am doing 45 MPH with 4-6 adults hauling equipment and drinks, ect...ect. So there is a noticble difference in these factors.
What elevation are you currently boating at?
50 MPH is really respectable for a smaller boat. Understand that you really cant do much more without starting to shell out $$$ for a few more MPH. The golden rule from my friends in the offshore life is that for every MPH over 60, you will spend $1,000 per MPH per motor. So if you have a twin engine you just made that $2000 per MPH over 60.
Get back to us and lets see if we cant help you achieve a little more speed.
