My new to me cruiser has a self draining deck with drains in the stern corners and from the channels the hatches sit in. However, water puddles up on both sides which is a bit of a low spot. I'd like to add a couple drains in those spots.
I think I can figure out how to cut the holes and mount and seal it; I'm wondering if I can run the drain hose to an existing one (from the corner drain) and "T" into it? Or does each drain need to have it's ownthru-hull? I don't want to cut another hole in ths side of the boat!
Thanks.
Thanks.
