2wheelmadman
- May 18, 2009
- 9
I'm just about ready to pull the plug and wave bye bye to this piece of junk!
It's a 1999 3.0 L GM, I've had the valves done, re-set them, checked compression, replaced the riser, the intake/exhaust manifold, t-stat, wires, plugs, distributor, coil, rebuilt the carb, replaced all hoses, checked timing, fuel filter, oil and filter, and every other thing known to mankind, and I just cannot get this engine to idle!
if I set it for below 1100 rpm it drops further and then surges back up to 1200 rpm and will keep doing that indefinitely.
I can't run it like this, as the shift into gear at 1100 will take the drive out sooner or later.
Has anyone got any ideas or suggestions?
Thanks guys.
Thanks guys.
