malcolm327
- Jul 21, 2009
- 6
I have a 1980 Mercury 115 outboard ( serial# 7148217, model# 1115620) with a cracked lower gear assy (lower leg) housing. Water got in and froze. Crack is located on the torpedo in a v shape and approx 7 inches long if it could be sealed or welded. I have been told by dealers not to weld as warping may occur and cause misalignment of shaft/bearings. New case is $1600 Can.
1. Has anyone had success with welding or sealing?
2. Any suggestions for obtaining a used case?
3. Will a case from another motor (ie 85 to 150 hp)work?
Thanks for any help
Malcolm
Thanks for any help
Malcolm
