Re: 90 Johnson very smoky
I have a 93 Johnson 90 that has the VRO missing so I carefully mix my gas and oil 50:1. After it warms up and I zip out to my fishing area I shut it off for several hours and just use my kicker. When I fire up the Johnson it smokes real bad. Is there something I can check in the carbs to fix this? Could it be something other than the carbs like a gooey gas tank? Thanks
does it smoke only when you fire it up or the whole time?
if it smokes only when you fire it up its normal... motor is not up to temperature and theres some left gas/oil in the cylinders...
if it always smokes well..... you need to do a tune up.... follow the linkk below on how to decarb your carburators... if you have recirc check valves replace them, they might be clogged up... carbs linc and sinked, correctly? what kind of oil are you using? synthetic and synth blend smoke less than regular.... do you have the corect spark plugs, correct range? is timing right? gooey gas tank posible.. always use fresh gas, no older that 1-2 months....
good luck
