geddron1976
- Jul 14, 2009
- 24
Hi guys..
After reading a lot of really interesting posts in the past on these forums, i finally and sadly am needing to start a new thread of my own
I bought a used 17' dory with a wonderful 1986 3 cyclinder evinrude 60 vro ptt.
Heard it running and she sounded purrrfect.
I recently used the boat and while flushing the motor with fresh water in a tank i noticed the following..
i seem to have developed a tapping noise.. it is present when idling but remains when throttling up, the only thing is that it doesn't seem to get much faster if any when i throttle it up?
It can only be heard while the hood is off but it sounds similar to tappets on a car motor?
I have a feeling it could be small end bearings, however, i know near nothing about these motors. should they make any tapping noises at all?
I would have thought that if (as someone has suggested) it could be the big or small end bearings, surely it wouls increase in speed of tapping as the engine speed increases?
I believe the VRO is working ok, it is using oil and the engine does smoke a little when starting and when moving from idle to powering up. I assume the smoke is the 2 stroke oil as it smells like it and has a blue-ish colour..
can anyone tell me how much oil it should use after running a full 33 ltr (6 Gallon) tank through the engine?
Should i be worried about the tapping and if anyone has any ideas what could be causing it i'd be greatful for your advice.. I am crossing my fingers that a rod is not about to come through the block!
yours hopefully
a very worried boater!
yours hopefully
