fishingman220
- Jun 13, 2008
- 568
ok, i had to pull the drive to pull motor, reinstalled motor, did alignment with the correct tool, it slides in and out like a dream, now i am trying to get the drive on and i can just barely get the drive up on the studs and then it just locks up, will not budge. now i did change the o-rings on drive shaft. i did have in foward when i pulled it and it hasnot moved. the female on the housing is straight, but the little 90 degree shift part on the drive will not stay straight, it will go staight but as soon as you pick up the drive it moves. i have been trying to get that to stay straight so i can rotate the splines but cannot get it to turn. someone please help before i loose my mind. is there a video somewhere on installing out drive?
