Re: Prop Diameter ?
David, I regularly help people get a better prop than the one they are running currently. It gets better speed or it gets their RPM to where they ought to be instead of way too low or high. I am not a magician and so I am not perfect, but I do get it better the first time. If you will go through the posts on here you will see that.
If somebody is trying to get the absolute maximum speed out of their boat it is a trial and error process, and it takes trying many props to get there. But your problem is simple, you have wayyy too much prop slip, and you only need to decrease your prop slip to raise your speed.
Having said all that, you are quoting a range of RPM for a certain speed, I need good numbers to work with and the ones you have are not good numbers. A boat at any point in time and circumstances has a specific speed at a specific RPM, and with the numbers you have that is not the case. Here is an analysis if I use your ranges for RPM and the speeds you say and you can see why I need exact numbers.
Prop Slip
Here is the information I need if you want my help.
Iboats Boat and Motor Info
1. Year, make and model of boat
2. Length, width and base weight of boat, look for boat decal on back of boat
2a.What is the recommended HP for your boat
3. Number of people and gallons of gas normally on boat
4. What do you use the boat for
5. Is it a Deep Vee and if so how many degrees of deadrise
6. Year, make and model of motor
7.
HP and gear ratio of motor IMPORTANT
7A If you have a mercruiser and don?t know the ratio get your serial off the outdrive and go here
http://www.sterndrives.com/mercruisersterndrives.html
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
12. Make, model, diameter, pitch and whether SS or aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. If you do not have a tach you can buy a Tiny Tach for $ 50
14. Are you at sea level or a higher elevation, give us the elevation in feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the forgoing could be the reason your prop is not attaining full RPM
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
17. Does the prop show any damage that you can see
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
