Silvertip
- Sep 22, 2003
- 28,764
Re: Cavitation - End of My (Bleeping) Rope!
The prop hub is splined to the engine prop shaft. But the hub has a rubber cushion between it and the blade area of the prop. If that bond lets go you have prop slippage. If you have an XHS or similar hub system this is not an issue. But since you have tried different props, slippage is not the issue. Pontoons have very turbulent water at the rear and the prop needs to operate in that turbulence. The reason the Big Foot motors were made available is because they can swing bigger props and sit a bit lower in the water than the 1.83:1 gearcase. That setup is simply not meant for pontoon or work boat service. My Misty Harbor is powered by a 40 HP Suzy 4-stroke. It has a 2.27:1 gearcase, swings an 11-1/2x11 prop and does not ventilate. Think of the advantage a similar gear ratio of a Big Foot (or the 75/90 HP motor) and a 14 inch diameter prop would provide you.
