Help me find a cure!
My Zuzuki DT55 year about 1986-1988 running on two cylinders only, the one in the middle (no 2) will never more pick up under no-load an load conditions. One day the problem appeared suddenly without any close signs. Just after a short break in waterskiing we were able to proceed and then it suddenly occurred after starting (in connection) the engine.
Measures been taken ?
New plugs
Checking the spark, status OK
Swapping coils and wires between no 1 and no 2, no difference, the engine still bogging
Compression test -
cylinder no 1 9,1bar
cylinder no 2 8,7bar
cylinder no 3 9,4bar
Pumping the primer when it?s bogging, no difference
Etherspray, startgas direct in the carb, no difference, rather worse when affecting the healthy cylinders beside.
Next step in my plan is the carb, dismantled and clean.
Anyone who have better advice? I?ll really appreciate any suggestions!
Thanks
New plugs
Compression test -
Thanks
