JustJason
- Aug 27, 2007
- 5,319
Ughhh... Another toon from hell!!!
Early 90's vintage. Lost foam cast block (integral head)
Compression 80 and 80
Spark, hot and blue, jumps 1/2in on the board no problem.
Fuel, Carb and pump rebuilt by yours truely... flow tested it with a blowgun. Was dirty before but not the worst i've ever seen.
This thing doesn't do anything. Wont start, stutter, sputter or fart. Not even by shooting fuel down the throat of the carb.
Timing, Hooked light up to plug wire and hooked plug wire up to the board. In neutral Timing is steady at 8btdc, when the throttles wide open, timing is 36, as per specs. So I can't imagine its the spark timing or something with the triggers/flywheel. Verified 0 on the flywheel is #1 tdc. Even checked for a bent crank and the pistons are exactly 180 apart.
I know I'm firing via using a spark board, a timing light, and my KV meter. I'm getting 5KV at cranking rpms.
I check the reeds by just placing my hand over the carb. There is no blowback. But I don't really feel my hand getting sucked in either??? Placed a light plastic baggie over the carbs throat and cranked it and even that didn't get sucked in. Pulled the carb again and sprayed J/rude 6-1 foaming oil at the reeds while cranking and it does get sucked in a little, but not a whole lot. I don't know if that is normal for a 9.9 or not??? Checked the bleed system just for the hell of it, thats working the way it's supposed to.
So like... what the H??? Anybody know if these 9.9s can pull an air charge from anyplace else other than through the carb? No block/gasket leaks that I can find with foaming oil.
Going back to it in a bit and am going to lock each piston at tdc and do a leakdown test. I'm going nucking futs... anyone have any insight?
