New to the forum so hello. I've been searching for a couple of hours now and no exact answer to my problem.
I bought this motor with a 12ft aluminum boat in October. The carb was clogged. Under the bowl, I unscrewed it and poked it with some wire. Ran great. I still see that there is some parts in there that won't come out (behind what I cleaned... like 2 metal tubes) I believe I read that I would need a special tool maybe?? I'm not even sure it needs cleaning. The motor ran great though. Put it in a large trash can. It idled for prob 20 mins. I did have to play with the top screw. Unfortunately it is missing the knob. The top of the black plastic intake piece wasn't even screwed down. I'm not sure if it matters but I would think it does because it looks like it catches air off of the fly wheel.
I took it out last month and was having a major problem keeping it idling and noticed that the top screw (inside the black intake box) had tightened itself closed. I adjusted and could watch it do it again. So I got home and put some teflon tape around it. It seems to have worked but still cant get it to idle. PS, I do not have the top plastic piece of the intake box on it at all. Just makes the screw easier to get to because I have no knob.
Here is my main problem. The motor purrs like a kitten when its running. But 90% of the time it will not start back up, even after 2 minutes.
I've put new plugs in. New hose and bulb. No new hoses on the motor as of yet. Fresh gas. I just think it's weird for it to run so good then literally not start.
Oh yea, had the float pin stick in the up position yesterday so it wouldnt get any gas. Got it workin after a quick teardown. Does that need to be removed and cleaned or was it just a fluke from sitting up a week?
Thanks in advance for any suggestions. It's a strong little motor I just wish it were more dependable. I mainly do rivers and I need it to crank and idle before I'm in the bushes with the snakes.
