Re: finally starting restoration, '64 Glasspar Marathon
For as long as it sat rotting-about 30-40 years- I thought it was in pretty good shape, also. So far, the hardest work looks like the deck. It's rotted all the way back to the transom. and then I have to build and upholster two seats. The ones I have in my Baretta, look a lot like the rotten ones I took out of the Glasspar. Are they somewhat interchangable? The only real difference is that on the Glasspar, the two places where the seats were bolted to. Whereas in the Baretta, the seats sat flat on the deck.
Another thing, too. Is there any reason I should separate the two halves of the boat to work on it? I believe that the small shelf in front of the motor is removable. Or should I just try to replace the decking as it sits?
