I have a 2.5l OMC that I've been having problems with water in the oil.
The end of last season I had a problem with the boat not starting after a short ride from the dock at very low speed. Water was coming up between the exhaust manifold and the head. I took the exhaust manifold off and noticed there was a freeze plug that wasn't seated evenly, I took a socket and beat the freeze plug in so it was the same depth all around. I thought that may be where the water was coming from so I put the exhaust manifold back on with a new gasket. That fixed the problem of water spurting out from between the head and the exhaust manifold.
I had to make a gasket for the riser elbow from a rubber gasket material.
After having it back together, I didn't get the riser elbow tight enough, because I could see where water was seaping out where I put the gasket I had made... I took that back apart and made a new gasket again, but this time I tightened it harder and it doesn't seem to be leaking water anymore.
The problem is I still get water in the oil. I almost tore the head off thinking there must be something wrong there. Good thing I didn't because I don't think that's the problem anymore. Here's why...
I also had a starter problem and the boat was starting very rough, took many attempts to turn over. I put a new starter in it and if I keep the boat at high rpm I don't seem to get any water in the oil.
The thing fires right up with the new starter, shouldn't it hydro lock if water is getting in the oil through the exhaust?
Any help is greatly appreciated.
Thanks
Thanks
