maxum247
- Sep 18, 2007
- 1,363
1989 125 hp Force Outboard. What would (most likely) cause the #1 and #3 cylinders to fire weak or not fire at all. I've seen this asked several times while searching the different forums, but I haven't been able to determine exactly what causes the problem or in my case solve it so far and my Clymer manual doesn't seem to cover the issue.
I know there's a reason for it, maybe more than one, anyone had this problem and discovered the answer or a way of solving the problem short of replacing everything from the ignition switch back to the motor a peice at the time until possibily finding the problem?
Could it possibly be partly mechanical in some way?
Thanks!
max!
Thanks!
max!
