lunker0477
- Jun 26, 2008
- 21
have a 1994 p200tlrs pro v having problems with a mid range surge and iv lost 600 rpm , boat come up on plane fine then surges like its starving for fuel through out mid range then will only run 4800 rpm on top end used to turn 5400 to 5500 rpm ,changed and cleaned all filters ,2 new fuel pumps ,1 had a small pin hole in it, but id didnt fix problem,new lines from primer ball to carbs,carbs rebuilt by yamaha dealer to the tune of 500 dollars,still not right,he has carbs off again going through them,read in another post that thermostat malfunctioning could cause a lean condition anybody got any other ideas.thanks
