Re: 150 johnson primer bulb tends to collapse
Usually caused by an obstruction btween the fuel and the primer, but sometimes by the primer bulb's own valves.
Also be sure that the arrow on the primer bulb is pointing to the engine, not the tank.
Common causes for the collapse of the bulb are bolcked or unopened tank vent,
cligged fuel pick-up screen in the tank, failed anti-siphon valve and/or clogged fuel filter.
