I have a Chrysler 115 outboard that I got runnig this year. I replaced the head gasket, water pump and impeller. I also cleaned out the cooling bypass valve. I added some key gauges to monitor it while its running. The gauges are the water presure and the temp gauge. My consern is when I put the engine in a test barrel or in the river. (when cold) , The water presure gauge shows good pressure 10- 15 psi and after 30 sec, it drops off. It never comes up again but a little above stop. even at 3000rpm. water is heavely coming out of the talttell holes. the temp on gauge reads 135 pretty quick I think and at cruise its reading 165 to 180 if i push past cruise.At idle, ican put my hands on the heads. Do I have a bad thermostat that is opening to quick? Runs great though. Any sugestions welcome.
Thanks
Thanks
