I have a 1988 Malibu Skier, GM 350, "5.7 Ski" with a direct drive Borg Warner Velvet Drive inboard transmission. The boat idles well and revs normal when in neutral but out of the hole to pull a skier it coughs and sputters having trouble going up in RPM. I have replaced the points, condenser, rotor and reset timing to factory spec. I have had the carb. rebuilt, replaced the fuel filters and will replace mechanical fuel pump tomorrow. I will also clean the fuel lines. Some people tell me it is the fuel system. Some say it is the distributor and advise changing to an HEI. I also drained and cleaned the transmission case and filter. Everything on the boat is 21 years old with no problems. I have no problem replacing the parts one at a time as the boat has been bullet proof for 21 years. I just don't know where to go next!
The boat purrs like a kitten in the front yard and I will give it a lake test next week. Any advice where I should go next if the lake test goes bad?
Thanks, Bruce
Thanks, Bruce
