Re: mercruiser mcm 165 water in oil
i bought a head gasket set from sierra and got everything back together runs good temp stays at 120 with the muffs connected at idle one thing i cant find is the hose to the valve cover to air cleaner i know that helps with the pressure like a pcv valve i plan on running some sludge remover through it, and changing the oil again. i removed the valve cover, after i let the motor run for about total an hour, to retorque the heads and there was alittle sludge on the valve cover none on the head, can that be due to the hose? any suggestions would help thanks.
