ward cleaver
- Dec 15, 2007
- 174
Re: 1961 Johnson 40hp doesn't fire - repair or part out?
Ok per the instructions in Top Secrets:
I removed the prop; no fishing line, no spline, prop has some nicks but since they were really small I smoothed em out with a grinder and it looks ok. Put new cotter pin on the shopping list.
Removed the drain and vent screws on the lower unit; no sign of water intrusion (milkiness) and no shrapnel in the fluid. The fluid did smell a bit burned tho. So now I'm ready to fill 'er back up and reading carefully this time I see that I am suppose to fill thru the drain hole on the bottom until it comes out the vent hole at the top. Well now THATs a problem! This think weighs way more than I can lift. How am I suppose to turn the whole thing upside down so I can fill from the drain hole? And if I do, won't it just run out the vent hole? There must be some sort of duh-thing I don't get.
