I recently replaced the quadra jet carb with an Edlebrock 4barrel conventional bore. The chevy 5.7 litre engine starts and runs ok but seems to hold the shift lever in gear until you kill the engine, I replaced the kill switch to no effect. The Carb linkage had to be modifed to fit the new carb I'm wondering if the linkages of the two are integrated in some way that throws the shifting off. It shifted ok before the carb was installed. Rich
