swimmin' for shore
- Oct 25, 2004
- 490
I have a dual battery system on my 16' aluminum boat. The batteries don't seem to be holding a charge, and for that matter, even seem to be draining whatever charge I put into them. When I put the speed charger on either of the 2 batteries, they register below 20% of full charge. No matter how long I leave the charger on, they won't go above 70%, either. Last Wednesday, I charged the batteries to their 70% threshhold, took the boat out for a run, shut it down to fish for about 6 hours, and came home. While fishing, the only thing I ran was the anchor light and the radio for a short while. At the end of the night, I started my motor and took it in. When I got home from the river, I shut the battery switch off and left it so. Over the weekend, I took a 5 hour drive with the boat to help my dad put his own boat in the water. We never finished his work, and didn't make it to the water. I drove home on Sunday, hooked up the charger to check battery %, and it registered between 7-10% charge on each battery.
For history on this, these are Wal-mart deep cycle batteries. The other set were, as well. I am running a Johnson 50 hp motor currently, but I lost the last set while running on a Mercury 40 hp motor. By that, I believe that this issue does not have anything to do with the motor. Both motors have charging systems that are working, although the Johnson is putting out slightly less than I believe it should be, at only about 13.0 V.
Setup wise, each battery has one hot lead leading to the perko isolator. Beyond that, there is nothing else hooked up on the positive side. On the negative side, pretty much everything on the boat is grounded. I probably need to run a bus bar, but haven't gotten that far yet. I'm very good about remembering to turn the switch to the off position. I've checked it and am confident that I have no draw from any wire when the switch is in the off position. My batteries both sit on rubber-backed carpet, which sits in a wooden-based enclosure.
Sorry for the long post. Thanks in advance for any help you can provide. SFS
