speedcat2000
- May 25, 2009
- 34
I have a 1981 Johnson 35HP. I've spoken to several mechanics and explained the issue where it jumps out of gear. The consensus seems to be one of two things:
1) Prop connection (?) is broken so prop won't spin with motor
2) Either the forward gear, or the fwd gear clutch, or both, are stripped and need replaced.
Most people think it will be 2) and will be $300 in parts alone. I live in Seattle & wondering if there are any cheaper options. Also need a good outboard mechanic as I am pretty clueless myself. The shops around here seem to want between $75-$100 per hour, not sure I can justify the end-run cost on these old motors.
(edited.. found the "comp test sticky" - thanks).
Also have 1975 85HP Johnson, need compression test. If anyone has a good compression tester I could borrow in the Seattle area I'd be psyched. Also would gladly pay for some help with either motor.
Sorry to lump several questions into one thread. Thanks for any help you can provide with these questions.
Cheers,
Jeremy W.
Seattle, WA
Cheers,
Jeremy W.
Seattle, WA
