jasonsnova
- Feb 26, 2009
- 21
ok so heres the story, my 3.0(181,4 cyl) was messed up had a knocking oise so we took it out and did a total rebuild, block sleeved, new pistons,bored .40 over, new cam & lifter etc.... we'll took it out for its intial test run saturday and it seemed to run we'll except it wouldnt rev past 4000 rpms, previously even with low compression and and a knocking it would rev till 4500-4600. it was properly timed, the only thing is the carb has a slight dead spot (which it had before,) so i checked the plugs and it looked slightly lean, but other then that all seemed well, suggestions? ....i did check out the cam specs and it was a stock replacement ( same specs as OEM) seems wierd ..... any ideas....
